Fuel leak
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Sep 16, 2017.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Hello guys, I'm kinda at a loss for words.. been working on a fuel leak for a long time.. I can't pinpoint where it's coming from replaced petcock via Len and don't see any other places it's dripping .. it seems do be dripping around the shaft and dripping out this part? Any ideas would be greatly appreciated it's an 82 seca 750
  2. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    The petcock I got from Len has on off and reserve if that helps...
  3. k-moe
    Open the oil cap. You'll find that there is gas in the oil.
    You need to (at a minimum) replace the float needles and float needle seats, as well as set the fuel levels.
    Unless you requested that Len send you a petock that has on, off, and reserve, you should have one that has on, reserve, and prime. Double check that.
  4. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I've gone to church on my carbs already earlier this year.. could something be stuck?
  5. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    And I requested that kind of petcock cuz that's what was on the bike also I am not sure there is fuel in the oil the oil level seems normal .. how exactly would I know besides popping the drain open?
  6. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Also it only seems to leak fuel when the bike is warmed up
  7. k-moe
    The oil level probably looks good because the fuel is dilluting the oil, and causing it to leak out of the output shaft seal, or from the breather tube.
    Any tank leak would show signs of fuel on the frame, or the outside of the engine, not coming fom the inside of the frame.
    STOP running the engine until you get this fixed.
  8. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Open the oil fill cap and smell.
    Did you wet set your float levels after going to Church?
    Did you put new float needles and seats in when you went to Church?
  9. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Yes I did all of that, so I'm assuming a stuck float?
  10. Stumplifter
    near Irma, WI
    Hitachi's set to 3mm +\- 1 from the top of the carb bowl?
    It is possible that a float is stuck.
    Try this; get a small glass jar, drain bowl number 1 into it, mark where the fuel level is. Empty jar, repeat for the other bowls... if one is really high then the float is stuck.
    Some claim tapping on the bowl with a screwdriver handle will free it. I would be inclined to remove the rack and see what is going on.
  11. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Awesome,, I'll do that thx so much..
  12. XJ550H
    from pics i would say fuel is leaking out drain in airbox carbs are overflowing into airbox.
    if you have pods fuel is pouring out of them
  13. schmuckaholic
    California
    I would do that anyway. Even if you unstick the float needle once, it'll likely do it again.
    I've said it before, and I'll say it again. Make sure the floats don't hang down too low; if they do, the needles will be pulled off vertical and they'll bind in the seats. Causing the bowls to overflow.
  14. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Ok I took bike apart .. replaced the gasket from fuel gauge that was dripping some.. still leaks down the frame.. took pods off no fuel coming out of them.. now what?i can't seem to trace where it's coming from
  15. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I drained oil for the heck of it.. no gas in the oil at all.. it only drips when bike is off...
  16. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I replaced the gasket and seals on tank sensor.. it still leaks.. I drained carb bowls.. same amount of fuel in every one.. it only leaks after I shut the bike off and it takes a few mins to drip.. small amount out of where I showed pictures.. the circumference of a basketball...I don't wanna go randomly replacing needle valves unless u guy truly think this is the issue.. I didn't have fuel in my oil.. seemed very normal to me... I've had fuel in my oil before and it was easy to tell because it was so runny.. and tips would be greatly appreciated
  17. XJ550H
    have you changed petcock seal? fuel line clamps tight? proper size fuel line? 6mm
    try removing tank put on news paper see if tank is leaking.
    use an axuillery tank to trace down carb leaks possibilitys
    if you have no leaks in tank or not sure put tank on a shelf get a few feet of fuel line remove carbs.
    then run line to carbs away from tank brace up carbs in a vise or between 2 boards or build a carb rack holder .
    weight of fuel in tank will help put petcock on prime
    basicly get the fuel system off of the bike to where you can isolate it and its components.
    if you can put tank in sun fuel will heat up and put a little pressure in the tank.
  18. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Brand new petcock via Len... I can hook up my auxiliary tank to see if it's truly not tank.. that's a good idea.. how would I know carb is leaking or not besides taking off pod filters?
  19. k-moe
    The would be fuel in the oil, or yellow stains on the outside of the leaky carb(s) from fuel residue. Because the fuel is getting back on the swingarm pivot, there is litle to no chance that the carbs are involved at all.
    I'm now leaning towad this being a petcock or fuel line issue. Dripping for a bit, then stopping, is indicative of a seal or line that has a small hole, which swells shut afer fuel is present. It could also be a slow weep that pools over time, but is not noticeable once the engine warms enough (fuel evaporating before enough can drip to form a puddle).
    I'd recommend pulling the tank, and looking for any signs of pinholes, leaks, drips, weeps, etc.
  20. XJ550H
    take carbs off bike and put a rack on them to hold then up right with clamp
    with tank off clean off gas on bike hook up aux tank see if you get a leak on bike. fuel weight may not be enough in aux tank so try method suggested above .
    tank high on prime carbs low and away from tanks
    Timbox likes this.
  21. XJ550H
    some bike shops can pressure test tank
  22. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    I'm using 1/4" hosing for gas line
  23. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Well with an aux tank it didn't leak at all.. it must be with my gas tank.. I have some two part caswell I bought last year and never used.. anyone ever do this? Do I take out my gas gauge? How do I get the minimal rust out of my tank? Do I take out the petcock ? Thanks In advance
  24. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Or would u guys find the hole and jb weld it? Or something similar?
  25. XJ550H
    pet cock out sender out blanking plates to seal there are products to neutralize rust, rust reformer , or phosphric acid. tank liner instructions spell this out .
    or there are several ways listed in info overload to remove rust
  26. XJ550H
    shops can silver solder seams and holes but at this point the most cost efective thing is derust and line
  27. XJ550H
  28. k-moe
    Of what type? There are literally dozens of types of 1/4 hose, even when just looking at fuel-rated hoses.
  29. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    It was a fuel line at auto parts store.. black rubber
