Higher rpm
Discussion in 'XJ DIY How-To Instructions' started by Viking_317, Aug 1, 2022.
  1. Viking_317
    Viking_317 New Member
    Indianapolis, IN
    Hey guys i know there are other threads on this. Have an 82 550 maxim. My rpms will not go below 3000 without stalling. Ive cleaned and rebuilt the carbs. Ive replaced the carb boots. From what i can tell there is no vacuum leak. Ive tried adjusting the air/fuel mixture screws 2 1/2 turns out and adjusted while engine running. Adjusted idle screw and thrittle adjustment. The floats are set at 21.5mm dry. The idle seems to stay around 3000-3500 when sitting. Goes up to 5000 when riding and using throttle. Its not shifting hard, except when first putting in 1st gear at take off from starting engine and warm up. Rest of gear shifying is smooth. Only noticeable thing happening from the rpm level is fuel consumption. Im at a loss on what to do. Also, the manuel says not to use the attached tachometer for idle adjustment as it is not accurate. I need to get a portable tachometer to try. Any suggestions welcome.
  2. Tim morris
    Tim morris Active Member
    Hopatcong NJ 07843
    Did you vacuum sync the carbs ?? Pull fuel tank get a good book and 1 # hook up a temp fuel supply 2 and go over it again. You're close
    k-moe, jayrodoh and faffi like this.
  3. faffi
    faffi Active Member
    Norway
    Yes, carbs out of sync can cause exactly the issue you describe.
    k-moe and jayrodoh like this.
  4. Viking_317
    Indianapolis, IN
    I did use carb calibration gauges. At the time that was before i replaced the carb boots and they were in sync but still high rpm. I can do another check now that they've been changed out.
  5. Viking_317
    Indianapolis, IN
    I can definitely do it again.
  6. k-moe
    What happens if you back-off the idle adjustment knob?
    Is the throttle cable sticking at all?
    faffi likes this.
  7. Viking_317
    Indianapolis, IN
    If i turn the idle screw counterclock wise it will drop from 3000 to engine stopping unless i mainrain some throttle. The throttle cable is not sticking at all.
  8. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    It doesn't take much knob rotation to affect the idle. Maybe too much?
  9. Viking_317
    Indianapolis, IN
    Could be part of it. I dont turn it much. Kinda go back and fkrth trying to find that sweet spot.
  10. Huntchuks
    East Rochester, NY
    Maybe not the issue then.
  11. k-moe
    Likely not the issue.
    I need to have a think.
  12. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Sync again, mixture again, sync again. One, or maybe two of the carbs are shutting off.
  13. Oblivion
    Oblivion Active Member
    Northeast Illinois
    WAG, but maybe not carbs? Something in the alternator/coil system not passing enough juice at low RPM?
  14. Franz
    The alternator doesn't kick in until 2000rpm.
    Oblivion likes this.
  15. Viking_317
    Indianapolis, IN
    Will try that as soon as i get my sync guages in. Thanks
  16. Viking_317
    Indianapolis, IN
    Rectifyer?
  17. Viking_317
    Indianapolis, IN
    Can you expand on that please?
  18. Franz
    I read that on the forum somewhere l will try and find it.
  19. Franz
  20. faffi
    faffi Active Member
    Norway
    That does not sound right, you need at least 13v to get a charge worth having going.
    Franz likes this.
  21. Franz
    Yes good point. I think when l checked my alternator it was about 14.4 volts.
    faffi likes this.
  22. Franz
    I think it refers to the regulator box heading, perhaps l have misunderstood this :eek:.
  23. Oblivion
    Northeast Illinois
    Indeed, I took it to mean the regulator voltage feeding the rotor fluctuates thusly to maintain the correct output voltage at a given RPM and load:
    “This "electromagnet" rotor is fed a current which is adjusted to keep the output of the alternator between 14.2 and 14.8 volts (with no load).”
  24. Franz
    Yes must be that the regulator voltage feeding the rotor.
  25. Viking_317
    Indianapolis, IN
    Update!!:
    After many headaches, i finally found that the pilot jets that came with my carb rebuild kit were non-bleed type. I replaced, instant changed the way the bike ran and was able to get the idle rpm down to the appropriate reading. Thanks guys for your help.
