How to help, ignition switch
Discussion in 'XJ DIY How-To Instructions' started by timothy guay, Jul 28, 2018.
  1. timothy guay
    timothy guay New Member
    Missouri
    Help! How do I remove the ignition switch on my 82 Seca xj750. What all needs to be removed to access it for replacement?
  2. Polock
    it's been so long since i moved mine i don't remember. i can say that once it's off you can take it apart, clean and lube it and it probably will work like new
    Tim morris and timothy guay like this.
  3. XJ550H
    a 10mm socket ( if i remember correctly) with long extentions will reach the 2 bolts , pull off the ignition cover. then you will undo 3 connectors, and this link from xj4ever site
    Clean and lube the ignition switch
    timothy guay likes this.
  4. XJ550H
    if you remove the headlight bucket you will be able to get to it
  5. timothy guay
    Missouri
    Thanks everyone. I have a nos replacement, so taking apart and cleaning isn’t needed, just wasn’t sure how to remove it and replace with new old stock.
  6. Polock
    rule #1: ask first, spend money later.
