XJ750 Maxim overcharging
Discussion in 'XJ DIY How-To Instructions' started by John Xj750, Sep 12, 2022.
  1. John Xj750
    John Xj750 New Member
    Illinois
    I have a 1982 Xj750 Maxim and I am having problems with the electrical system. I just recently bought this bike and realized it was charging to 15.5 volts at anything over 2000rpm. I checked the rectifier per the manual and ended up buying another one OEM and same exact results. I have cleaned the flywheel rotor and made sure slip rings and stator connections had good resistance. What i find weird is when I pull the fuse for the headlight the voltage still goes up but it takes a while before it hits 15. I can't seem to find a short anywhere I have also tried a different battery. Would love any ideas on what this may be. Thank you
  2. Oblivion
    Oblivion Active Member
    Northeast Illinois
